doing the head is easy its just the timing i hated, you dont put cylinder 1 to top dead centre, instead you have to set all the pistons up level in the middle, but then you have to work out weather cylinder one's piston is on its up stroke or down stroke, to do the timing properly you will need some timing tools for the head to keep the cams in place, i just used big bolts they did the trick, i would purchase a haynes manual if you dont already have one, was a real big help for me
