Hellraiser
Hi all,
Diagnostics on my Bravo have turned up the ABS pump as being suspect - I have checked around on the net and it seems the HLX Bravo uses the Teves MK20 system, which is notorious for having bad solder joints on the electrical side (there's even a company specialises in refurbing these units as they are primarily used on Volvos) - does anyone know how to remove this unit, preferably keeping the pipes intact so I can remove just the circuit board and hopefully effect a repair? It would save me a hell of a lot of hassle if I could do this.....
Hellraiser............>
