I'm looking for confirmation of what i suspect after reading other threads.
i drove too and from work quite happily, a 75 mile round trip, non-motorway - it's a good fun route and plenty of changing gear and braking.
However when i got home, the problem happened.
i pulled in to my road, put the clutch in and stopped the car, popped it in reverse, only to find the bite point was at the very bottom of travel. i managed to park the car but with little travel on the clutch before biting.
i went out an hour later and the same problem existed.
The following day i checked the slave cylinder and it was dry, i pulled the boot back and it was dry. so i re-assembled and tried the clutch and everything was fine. i was just putting it in to first, pulling foward a few feet and stopping, in to reverse and back again. did this several times and put the car to bed. everything was back to normal.
i took the car out today, and clutch was fine until i got to the end of the road, the bite point was back at the bottom of travel. over the next 2 minutes of driving round the corner to a friend, i all but lost the clutch. i drove the car back without a clutch (mostly because i can). when i got home, a 3 oint turn was fun as pressing the clutch did nothing.
i parked up, left the engine running, popped the bonnet and got a neighbour to press the clutch down, the clutch arm was barely moving. fluid in the reservoir looks fine, not dropped since i checked it first time round.
Im thinking that the resounding solution is going to be 'CLUTCH SLAVE CYLINDER" (pictured)
The brakes feel good, however i do have abs.
Do the brakes and clutch come off the same reservoir? (indicated in picture)
Cheers guys.
Cheers guys.
