the clutch has gone, making lots of noise and hard to get gears e.t.c so ive bought a new clutch and want to fit it myself, but ive never changed a clutch or removed a gearbox before.
ive searched for a guide how to do it on here but cant find one. can anyone give me a quick guide on what to do to change it and what i need to disconnect/undo. do driveshafts have to be popped out, meaning i have to undo hubnuts or can i drop a strut down ? can i do it without loosing my gearbox oil? where are the refil and max level holes? will i loose brake fluid and have to bleed the clutch ? any special tools needed? i have the basic's like a socket and spanner set and torque wrench.
all tips and advice welcome
Ive done loads of these, relatively simple
You need a basic ratchet set, a lend of a 3/4 t-bar/adapter/32mm socket for the hub nut, hammer, clutch centering tool, blue loctite treadlock, instant gasket for the gearbox top, torx set for the clutch (T6 bit if i remember) and 2 decent trolley jacks.
Personally i dont drain the oil from the box but it is recomended
Shafts out is a must or its an unholy mess to put back in as a whole. Yes ive tried it this way too
un steak the nut then use a 32mm socket to loosen the nut while the car is on the ground. Jack the car, disconnect the front strut assembly at the hub, turn wheel in desired direction then hammer the cv end of the shaft out. Dont hammer them too hard or the ends will become flared and youll have to dress them down with a small grinder. Break the clips at the couplings as youll have to use new ones anyway and out they pop. Be careful of grease dripping.
Disconnect the battery then remove it and the tray.
Disconnect the clutch slave cylinder (try to keep it compressed) and tie out of the way.
Undo the earth cable (held in with a 13mm nut) and undo the 3 13mm bolts that hold the linkage in place at the back near the starter. Now undo the 5 bolts at the top of the box. Disconnect the plug at the end and carefully pry it up. Be carefull, this is a fiddly part.
Starter has to come out.
If you have a fly by wire 1.2 (it has the cat at the front) take the cat off. Undo the 2 nuts under the car that holds it to the flex section, then the supporting bracket. Then take the fan out (a bit fiddly) tilt then slide down to bottom of the car kinda diagonally. Heatshield (bolts can ring with heat and age) then disconnect the 2 plugs for oxygen sensors. 9 12mm hold the cat in place.
The Engine/Gearbox must now be supported on a jack. Undo the bolts at the rear mount (2x 13mm bolts) and take off the mount (4x 18mm bolts, quite awkward and usually very tight but i had to use a spanner) Undo the bolts at the front mount (3x 13mm bolts) then take off the mounting (3x 15mm bolts).
Straight foreward to take the box off, just 5 bolts and one nut to take off (3x 19mm bolts with brackets around them, 1x 19mm nut at the back near the starter acting as a guide bolt and 2 bolts at the bottom of the box, 15mm and 17mm heads) Box can be fiddly to remove from bay, tilt down, move engine back slightly and slide box down, careful not to tangle with the subframe.
Inspect clutch, make sure you have the same one, then loosen each bolt by a quarter turn going round bolt by bolt.
Withdraw clutch. Viola
Sorry to quote haynes manuals but "Installation is reverse of removal" However.....
Make sure the clutch is centred correctly before the box goes on or you could damage the centre of the friction plate.
ALWAYS use a new release bearing. Sometimes these arnt supplied with the kit, check and ask for one if necessary.
Use blue treadlock on bolts to prevent seizure.
Clean surface of gearbox top to prepare for the instant gasket.
The part where the linkage goes at the top of the box caused me problems the first few times. Check that the little lever inside is sitting correctly square in the middle between the selector movers and moves with them as you move it by hand and adjust if necessary and roughly bolt on the linkage to test it before you apply the instant gasket (see pic below of what im on about) otherwise youll put it back together fully and be severely cheesed off that have a wonky gearstick inside that wont go into 1,2 or reverse...
Use lots of cv joint grease in the boots before re-installation, MRM-2 from a Fiat garage
Inspect the clutch slave cylinder for signs of cracking in the boot and when mounted back onto gearbox top test it and bleed it if necessary (takes brake fluid from the brake fluid resivoir and the bleed nipple is a 7mm nut).
Check connections, bolts and make sure your satisfied with the work before you start the car
Test drive
If i have missed anything let me know.
Hope this helps!
