Adrian Bravo said:If your dash has a mechanical odometer then its a mk1 147bhp non-variator type from factory. Im not sure about the sounds hopefully someone else can answer that one.
hi mate but all mk1s have variator and bolted onto the threaded end of the camshaft. if this fails it makes a diesel sound in the first start and also a huge power loss after 4000-4500rpm.because after that rpm it transmits the rotation to the shaft, thereby varying the the timing of the inlet valves by an advance of 9 degrees.If your dash has a mechanical odometer then its a mk1 147bhp non-variator type from factory. Im not sure about the sounds hopefully someone else can answer that one.
Sorry kevin siniper is correct I mistakenly thought the Mk1 did not have a variator.Hi, thanks adrian
But I am confused now as you said I don't have a variator on the Mk1, but siniper says they are fitted to the Mk1's. Are they just fitted to the 155's or the 147's as well. Thanks for the pics.
regards
kevin
Thank you for correcting my mistake siniper, I have rechecked my manualhi Adrian
I have a 98 mk1 hgt and %100 sure that it has a phase transformer solenoid valve thus a variator too.
cheers
Checked after I asked youlol, i didnt know i was called a manual
Hi, and thanks bulldog, but have had the car to bits today, and I would imagine if a variator is fitted it would be sticking out by the battery end. No sign of one. So back to the drawing board. Also checked coil packs with multimeter and all five show 0.7 ohms would this mean there ok. Or this to much.
kevin
