The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Forge Motorsport
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 08-02-2010   #1
help with lowering suspension
Hi have fitted some Bilstien lowering suspension to my hgt 155 the thing is the ride height is fantastic and looks good but there is too much of a thud when going over speed bumps. The question is would i benefit from putting the standard rear shocks back on would this make any differance. help please.
craighgt155 is offline
Old 08-02-2010   #2
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: help with lowering suspension
Depends how low it is, the thud could be the suspension hitting the bump stops. Springs determine the ride height, if its too low it doesnt matter what dampers you put on.
If its not the suspension bottoming out it might be the dampers bottoming out... pretty destructive to the dampers IMO.
Either makes the car unsafe.
Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque.
Ffoxy is offline
Old 08-02-2010   #3
Hi i have taken off the bump stops so i know it isn't them as it is the with them on, the new shocks are gas i think so could this be the reason.
Old 08-02-2010   #4
The handling of the car is fine it is just that when going over speed bumps the rear end gives you a good thud in side the car
Old 08-02-2010   #5
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
How low is it? 20 - 30 - 40 - 50 - 60mm lower than original spec? More?
With the bump stops off the suspension could be hitting the body! Personally I'd keep the bump stops on, and re-think the lowering strategy, all the dampers do is regulate the springs in compression & recoil, do the replacements have a longer travel than the originals?
Ffoxy is offline
Old 08-02-2010   #6
I think they are 40mm i got them of another hgt that was being broken up. The springs are definatly shorter but i think the shocks are the same length.
Old 08-02-2010   #7
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Shock length is immaterial really Craig its the stroke of the damper that matters. Seriously, 40mm isnt that extreme. I'd really keep the bump stops on...
Ffoxy is offline
Old 08-02-2010   #8
Yeah gona put them back on as i know it isn't them just one thing i just pulled of one of the rear shocks and pushed the shock in and when released it came straight back out but on the old shocks when compressed they stay in and have to be pulled out is the right.
Old 08-02-2010   #9
The old shocks will be standard oil-filled ones, they don't extend automatically like the gas ones do.
It could be that fitting lowering springs and standard length gas dampers has a different effect than on ordinary oil dampers. In either case it's not ideal as the stroke of the dampers should really match the springs. 40mm is about the limit for standard dampers, and in the long term they will suffer a bit in any case.
See how it goes, and start saving for Bilstein shocks...
bluejohn125 is offline
Old 08-02-2010   #10
The shocks are bilstein i will just have to get used to it.
Old 08-02-2010   #11
I got the full set of bilstein shocks and spring of another hgt for £40 bargain
Old 08-02-2010   #12
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Wasnt a crashed HGT was it?
Ffoxy is offline
Old 08-02-2010   #13
No not a crashed hgt it's on ebay for breaking
(G) Lowering and suspension MattyJLegend Stilo 12 04-05-2009 12:50
(G) Lowering Suspension... any reports of... Randy Stilo 7 17-08-2007 15:45
(G) MK 2 lowering suspension... pantalaimon Punto 3 03-08-2006 23:13
things to look out for...lowering suspension?? Clayton Lets Talk FIAT 13 27-07-2004 02:54
Copyright ©2002 - 2010 FIAT Forum
