The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 4 Weeks Ago   #1
Thumbs up Idle Control Valve 1.2
(hello everyone) im thinking of buying a air control valve for my 1999 brava,as mine is playing up will the car need to go on a computer once fitted thanks.
chris39 is offline
Old 4 Weeks Ago   #2
balny2000 has donated!
Re: air control valve
leave negative off battery for 20mins after jobs done, the ECU will reposition the IAV when engine is started.
balny2000 is offline
Old 4 Weeks Ago   #3
Bravo
Adrian Bravo's Avatar
Adrian Bravo has donated!
What engine do you have chris?
Wanted: Ink Black Bravo rear bumper and mirror caps.
Bravo Guides:
Adrian Bravo is offline
Old 4 Weeks Ago   #4
hi thanks for reply its the 1.2 16v: just to mention, i ask the guy that did the headgasket why the running water sound has returned told me he never got the head skimmed not happy.
chris39 is offline
Old 3 Weeks Ago   #5
whats the problem for you to need new air control valve?
and running water? is that when you turn the igniton on, but not the engine?
Karl
some need to get over themselves
K4RL is offline
Old 3 Weeks Ago   #6
hi the revs stay up at 15 to 20 thousand for a few secs, after been running then drop to normal.and the water sound is herd when the car is reving
chris39 is offline
Old 3 Weeks Ago   #7
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
you need it skimming it'll be leaking again
the icv is very expensive new but there is something you can try take it off and place 3 1mm washers under the bolts securing it lifting the hole control actuator 1mm from the throttle body
that should sort the problem
no ecu learning is nessesary
500 door handles fit bravo well chuffed
The Sultan is offline
Old 3 Weeks Ago   #8
if its the 1.2 16v, it cost me £111. for one (idle/butterfly position sensor) but not from fiat. they wanted £197. the black unit bolted onto the side of the tb
Karl
K4RL is offline
Old 3 Weeks Ago   #9
Thumbs up Re: air control valve
hi thanks for that (sultan) will try that.
chris39 is offline
Old 3 Weeks Ago   #10
Bravo 1.8 HLX FTW
The Sultan's Avatar
no problem let us know how it goes its's worked numerous times for me
Old 3 Weeks Ago   #11
hi got the head skimmed car running like a dream now no water sounds at all.however its still revs up to 1500 rpm this only happens if the car is rolling,say if im coming down my street in neutral the revs say up around 1500rpm until i come to a stop then drops to normal.tride the three washers (thanks sultan)did`nt seem to make much differcence.
chris39 is offline
Old 2 Weeks Ago   #12
Bravo 1.8 HLX FTW
The Sultan's Avatar
ok looks lie too much presure has built up inside the control valve you need to source a new or used one shame there so expensive
what happenes is the casing of the valve presses on the insides locking them from moving or returning properly releaving the presure with the washers usualy works
i'm not sure never taken one apart but something inside begins to swell in those be it rust or whatever
Old 2 Weeks Ago   #13
ok so ive got a new control valve how do u put the car in learning mode thanks.
chris39 is offline
Old 2 Weeks Ago   #14
Bravo 1.8 HLX FTW
The Sultan's Avatar
fit the part turn ignition on open throttle full and close again turn ignition off wait a minuite and start
Old 2 Weeks Ago   #15
help fitted new control valve now car not turning over???
chris39 is offline
(T) idle control valve PI7NO Punto 2 20-06-2009 08:25
(T) Inlet control valve shyster Stilo 5 01-03-2009 20:54
(T) idle air control valve robinstall Punto 0 23-06-2006 16:30
bleed valve/adjustable boost control VS FSE Powerboost valve Bushboy Lets Talk FIAT 33 22-02-2006 18:58
(T) Idle Control Valve Chipper Cinquecento / Seicento 4 17-12-2004 10:42
Copyright ©2002 - 2010 FIAT Forum
