The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Lamps by Post - For all your lighting needs
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 05-02-2010   #1
bravotony has donated!
Rubber Bandit Champion
Sidelight wire colours on for Marea headlights
Just fitted Marea poly's to my 97 hgt but just wanted to check the sidelight wire colours to rewire to the Marea sidelight holders in the guide it shows black and orange just wonderin if this was the correct coloured wires
bravotony is offline
Old 05-02-2010   #2
Moderator
Davren's Avatar
Davren has donated!
Re: Sidelight wire colours on for Marea headlights
According to Fiat wiring diagram, it's yellow/black for left and yellow/red for right sidelights.
Davren is offline
Old 05-02-2010   #3
Do the colours match up to the wiring on the sidelight holders from the Marea ?
Old 05-02-2010   #4
Established 1988
STU412T's Avatar
STU412T has donated!
Just been out to have a look, and this is how it is on mine,
Drivers Side - Yellow with Red Tracer coming off the wiring loom into Yellow with Black Tracer into the sidelight.
Passenger Side, Yellow with Black Tracer coming off the wiring loom, into Yellow with Green Tracer into the sidelight.
Life's journey is not to arrive at the grave safely in a well preserved body,...
but rather to skid in sideways, totally worn out,shouting..... . "holy crap, what a ride!"
STU412T is offline
Old 06-02-2010   #5
Does anyone have any idea what could stop my drivers side Marea poly from moving up and down as I changed motor but still nothin its in the complete down position, the passenger light moves up and down freely with no problem at all any ideas would be great cheers
Old 06-02-2010   #6
Bravo
Adrian Bravo's Avatar
Adrian Bravo has donated!
On top of the motor is a white plastic screw to adjust the height. You could turn it with a scredriver to see if the mechanical parts are moving ok.
Sounds like you have a few spare motors plug one in and see if it spins when someone adjusts it. The arm on the end of the motor has a little ball joint, is it in the socket properly?
Wanted: Ink Black Bravo rear bumper and mirror caps.
Bravo Guides:
Adrian Bravo is offline
Old 07-02-2010   #7
Tried 3 separate motors today all workin properly but not movin the light at all and the light wouldn't note manually either, is there any mechanism in the light unit itself that could break, plus is there any way I could move the light upwards by hand ?
Speaker Wire Colours Mark Elvin I.C.E 2 24-04-2008 11:52
wire colours Trist I.C.E 2 07-04-2008 19:28
(T) Lambda Wire colours. Help Please. Darryl Punto 10 14-08-2007 22:41
speaker wire colours the beasto I.C.E 2 30-12-2005 01:26
(T) speaker wire colours the beasto Coupe 1 29-12-2005 16:37
Copyright ©2002 - 2010 FIAT Forum
