Posts: 40 Thanks: 0 Trader Rating: 0 | this is?? ![]() the highlighted pipe this is..... i need it because..... the fact it somehow fell off and im driving without it means..... ![]()
Posts: 42 Thanks: 6 Trader Rating: 0 Drives: | Re: this is?? From what I can make out from your pic and pics in my haynes manual I think this is the hot air inlet pipe that runs between the top of the exhaust shield and the inlet ducting before the air filter. It is used to help the car warm up quicker in colder weather. There should be some vacuum connections on a valve in the air inlet this opens and closes depending on amount of vacuum to let in the hot air. I used to quite regularly run my older cars which had this system on it without it, as I could never find the right kind of pipe to replace the original.
| | #3 | ||
Posts: 40 Thanks: 0 Trader Rating: 0 | Re: this is?? doesnt seem to have affected it in anyway cheers
| | #4 | ||
Posts: 15,562 Blog Entries: 3 Thanks: 653 Trader Rating: 1 | Re: this is?? Not important, ignore. Cheers SPD
__________________ Marriage sounds like a grand idea. Divorce is more like a hundred grand | ||
