Posts: 37 Thanks: 0 Trader Rating: 0 | Fiat brava problem can u help please When i start up my brava i hear a rushing water sound somewhere behind the glove box it isnt leaking in the footwell, also when the car is moving in neutral the revs pick up and when i stop they go down again. Any ideas???? thanks
Posts: 4 Thanks: 1 Trader Rating: 0 Drives: | Re: Fiat brava problem can u help please Revs should pick up a little when car is moving and in neutral - this means, that VSS - vehicle speed sensor - is working properly. This is quite normal. Don't know about the water - have you checked coolant level?
| | #3 | ||
| | Re: Fiat brava problem can u help please When You hear that water sound it is very possible that You have an air in the cooling pipes, also check the coolant level. Fill up coolant and make a deaeration of cooling system.
| | #4 | ||
Posts: 37 Thanks: 0 Trader Rating: 0 | hi and thanks for the responds. but i had the car checked and the head gasket has blown could this be the water problem.
| | #5 | ||
Posts: 4 Thanks: 1 Trader Rating: 0 Drives: | Re: Fiat brava problem can u help please There are few symptoms of head gasket gone. Last time i had problem with heating, one of the excellent mechanic said it is a head gasket 99%. Took 1% chance, replaced coolant, removed air from the cooling system and it is working well now. Money saved. I would go somewhere else to confirm, i I were You, just to be sure.
| | #6 | |||
Posts: 17,418 Blog Entries: 3 Thanks: 784 Trader Rating: 1 | Re: Fiat brava problem can u help please
However, if not resolved promptly, it could lead to HG failure. Recheck the bleeding process. Cheers SPD
__________________ Your conscience is the bit that hurts when everything else feels good | |||
| | #7 | ||
Posts: 214 Thanks: 14 Trader Rating: 0 | Re: Fiat brava problem can u help please << but i had the car checked and the head gasket has blown could this be the water problem. >> Who did the check? and how did he do it. gushing water behind the dash can be a head gasket, I use to get it it basically means you are low on water and there is air in the system, you ned to find out why there is air in there, an engine compresion test and a coolant test for Exhaust gasses will tell you about head gasket, a coolant presure test will just let you know there is a circuit leak,which is a bit obvious with the water sound in the car. Mine turned out to be head gasket, didn't bother with compresion test just Exaust gasses in coolant and the obvious - water pouring out of exhaust tail pipe kind of gave it away.
__________________ Little Green 1200 CC machine | ||
| | #8 | ||
Posts: 37 Thanks: 0 Trader Rating: 0 | Re: Fiat brava problem can u help please thanks for the postes: it was the head gasket car runing like a dream now no water sounds.all though i have a other problem, when im driving the car on the road and hit a bump in the road,im getting a banging from the front end more so from the left wheel ive had the wheel off but ever thing looks in order???
| | #9 | ||
Posts: 214 Thanks: 14 Trader Rating: 0 | Re: Fiat brava problem can u help please Does in knock when riding over pot holes or small holes in road, lke knock , knock ,knock then stop, if so could be lower arm ball joint, quite difficult to spot ware here as when jacked up strut spring takes up movement so not easilly spotted, especially when you check this by your self, also just make sure your road spring is not broken, myself I would be looking at lower ball joint though, which if I remember rightly is all part of lower arm so you need to change the whole arm.
| | #10 | ||
Posts: 37 Thanks: 0 Trader Rating: 0 | yes thanks for that did suspect lower ball joint. having changed the front and back transmistion engine mounts and the right leg to no joy.yes it knocking on small pot holes.
| | #11 | ||
Posts: 37 Thanks: 0 Trader Rating: 0 | Re: Fiat brava problem can u help please hi can any tell me why my car runs lumpy when cold but fantastic when hot.
| | #12 | ||
Posts: 17,418 Blog Entries: 3 Thanks: 784 Trader Rating: 1 | Re: Fiat brava problem can u help please Moisture. Check for stray sparks. Cheers SPD
| | #13 | ||
Posts: 338 Thanks: 3 Trader Rating: 0 | Re: Fiat brava problem can u help please
__________________ Did you know that a "jiffy" is a 100th of a second so next time when you say in a jiffy you best be quick | ||
| | #14 | ||
Posts: 37 Thanks: 0 Trader Rating: 0 | Re: Fiat brava problem can u help please hi peps dose anyone no the symptoms of a faulty temp sensor, i have no engine fault light on.and not over heating.
| | #15 | ||
| | Chubbie27 | Bravo / Brava | 5 | 03-04-2008 08:30 |
| | danni06 | Bravo / Brava | 4 | 25-03-2008 09:56 |
| | scotlanddevil | Bravo / Brava | 0 | 10-09-2004 11:47 |
