rwilkes123
- Feb 16, 2009
- 11
- 2
:bang: Hi to every one this is my first post I have been at my wits:bang: end with this car the car starts then immediately cuts out I have replaced the ecu immobiliser & key, throttle body, coil pack, cam sensor & crank sensor the timing has been set with the correct tools the fuel pressure seams okay as well as compression. It will run when we supply easy start to the throttle body & we have put it on a new snap on computer twice the only error code was the cam sensor which has been changed for a new one. Does the throttle body need setting up by fiat as it is a mortised type i have tried the self learning procedure however the car still just starts then immediately cuts out please can someone help or i will have to scrap this car which is a real shame as it is a one owner form new before myself kind regards Richard.
