Technical Rear Heated Window
Bangor, Northern Ireland.
Hi all, hope you all had a good Xmas , and are getting geared up for the New Year !!
My problem is, basically, not all the 'lines' on my rear window appear to be working. I assume there are some sort od contacts that need replaced.
Can anyone tell me if this is a simple enough job, and if so, how to go about it ??
I had this in a Rover - you can by liquid silver contact repair paint from eg. Maplin (www.maplin.co.uk) - it comes in a small glass container and you use it like paint - make sure you shake it well or it won't work.
Just find whereabouts the heater "line" has a break in it and repaint it in!
Simple when you have the right kit!
HTH
Stuart!
