stubradley1
- Sep 3, 2009
- 15
- 5
Right where to start???
I have done a service new plugs,air filter oil filter and oil.
Been having problems with the engine management light coming on.
Figured it may have been because the exhaust was blowing around by the lambda.
Have had the exhaust fixed still doing it.
Replaced lambda this morning still doing it.
Disconnected battery for a couple of hours to reset ecu (hopefully)
Just took it for a test drive but within 200 yards light on again.
Also added some injector cleaner this morning just in case.
Any theories or next steps to take?
Should also mention fuel consumption is high and the engine takes ages to show normal running temp but if you spped up it goes back to showing cold.
Is the thermostat likely to cause the management light to come on?
I bought a scanner off ebay which is an obd2 type and also got an obd2 to fiat 3 pin adapter but it says error connecting so that's not much use.
Nearest fiat dealer is about 20 miles away.
Starting to get annoyed with it now lol.
