simon7685
Hi All
I have a 2001 (Y Plate) 1.2 Brava, it has done 42006 miles.
I know absolutely diddly squat about cars, other than topping up the oil and water and changing a fuse
On my way home last night the dreaded yellow engine management came on. I left the car overnight and this morning topped up the oil, which needed about a pint maybe, and topped up the water for the cooling system. It wasn't low but not quite full either.
I started the engine and the light was still on, though it seemed to be running as quiet as it normally does, no missing, coughing, burping or farting. So I took it out and drove for 3 miles, it was absolutely fine and drove as it normally would. The light then went out, I stopped at the supermarket of all places and when I came out and started the car the light was still out. After moving off the light came back on after a few seconds and ramained on all the way home (another 3 miles).
I left the car for abut half an hour and went back out and started it. No light, so I went out for a drive again (just a few miles) and the light remained out all the way.
I know nobody can diagnose this but I don't know whether to book it in to the garage or not. Truth is I can't afford it really. It had a major service and overhaul 12 months ago and has only done 2500 miles since, so its not as though it gets thrashed or anything.
I don't want something major to go wrong but if the light stays out am I safe to just ignore it for now, or until after Xmas at least. It is running as normal, no unusual sounds or bad handling or any symptoms what so ever.
Any advice greatfully accepted.
Thanks very much
Simon
Thanks very much
Simon
