julieiito
Member
Anyone help I have a (2001) Brava starting up I get a bit of smoke and can smell oil burning on a 45 minute run what is it? I also have to top up over a pint of oil every month Is it anything to worry about. Thanks.
It runs perfect no loss of power
Have you had any work done to the car recently, like a service? Any stains or puddles on the floor under the car. I'm just trying to rule out the obvious and cheapest methods first.
I.e. The oil filter may not be screwed on tight, then as the engine gets hot, the oil starts to burn on the engine and give you that unpleasant smell through the ventilation system. Sump plug may not be screwed tight. Cracked Sump. Etc. Is your camshaft cover leaking oil?
The smoke on start up, is that through the exhaust? What colour? Blue or White?
Other possible causes....
- Wrong Grade of Oil
- Oil Seal Leaking
- Sump Seal Leaking
- Cylinder Head Gasket Leaking
- Piston Ring or Cylinder Bore Wear
