luximax
Can anyone help with this nasty issue: somehow moisture crept into the ECU engine cable harness causing fatal corrosion at the ECU connection. I was able to repair the ECU, but do need a new cable harness connector. Fiat does not supply these connectors, and a new harness is VERY pricey. Does anyone have a spare connector? A Bravo or Marea connector would also fit.
Next question: how could this happen? Anyone see this happen before?
