julieiito Member Joined Dec 5, 2008 Messages 57 Points 105 Location Manchester Jul 4, 2009 #1 I have a Fiat Brava 98. Please can anyone tell me where the Indicator Relay (Blue Block) is? Thanks, Julie.
Adrian Bravo Speedbump grimacer Parked in the garage Written 5 guides Joined Mar 13, 2008 Messages 5,542 Points 1,015 Location North West Jul 4, 2009 #2 Sounds like you mean the indicator relay. It is under the steering colum, you can remove the lower cover by unscrewing 4 philips screws.
OP OP julieiito Member Joined Dec 5, 2008 Messages 57 Points 105 Location Manchester Jul 6, 2009 #3 Adrian Bravo said: Sounds like you mean the indicator relay. It is under the steering colum, you can remove the lower cover by unscrewing 4 philips screws. Click to expand... Hi Andrian, Cheers for the info I found it without any problem except I could not find the forth screw as only 3 there LOL. Thanks, Julie
