Posts: 1 Thanks: 0 Trader Rating: 0 | Hello, I'm new to the Fiat Brava, so any help here will be appreciated greatly. I just bought my wife a 1996 Brava 1.6 16V with 60k on the clock with one owner & full service history I got it really cheap. The only fault a knocking bottom end. I located a engine out of the same year as mine & similar mileage from a fellow car breakers...but the engine was like the Old Geyser when I removed the plugs & spun it over. Gutted. I removed the head & found the head gasket totally decayed & half a piston stuck on the side of the cylinder. Even more Gutted. He says he can get another engine but it is out of a later car 2000/2001.My engine has alloy inlet manifold & this other engine has plastic. The question is...Will this engine be compatible for the car ?
| | #2 | |||
Posts: 124 Thanks: 4 Trader Rating: 0 Drives: | Re: Brava 1.6 16V Engine Info ?
Also, they changed from a cable throttle body to and electric one in '01 so you would have to change that aswell + the ECU. Basically, 00 or under and you should be fine just as long as its a 1.6 Brava/Bravo or Marea engine.
__________________ Bravo HGT / HGT Turbo 280bhp / Saxo VTS / 306 GTi / Bravo 1.2 SX 125bhp. | |||
| | cosmo | Bravo / Brava | 3 | 02-09-2008 19:46 |
| | mi-len | Bravo / Brava | 1 | 02-05-2007 16:54 |
| | mr.manchester | Bravo / Brava | 3 | 19-10-2005 12:36 |
| | MyronBombay | Other Fiats | 2 | 02-09-2004 23:05 |
