The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Firela Motors - Your South London FIAT Specialist
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 30-06-2009   #1
Put petrol in my brava jtd
The other day went down to the fuel station for my normal fill up for the week. was filling my car whilst thinking whether to get a half or full tank of diesel. then lo and behold looked on the fuel pump meter and green hose in my hand and realised i just put half a tank of petrol. gutted
thugusher is offline
Old 30-06-2009   #2
Powered by Bamboo !!
udtrev's Avatar
udtrev has donated!
Re: Put petrol in my brava jtd
Have you drained the tank since ?
Try not to run it, but get tank and lines drained.
Trev
See Fred's latest excursion !
http://www.fiatforum.com/leisure-lou...ml#post2432709
udtrev is offline
Old 30-06-2009   #3
Site Sub Admin
sammiboo's Avatar
sammiboo has donated!
As said above - did you run it?
I did the same thing with my multijet GP - I accidently filled up with petrol. Paid for it and just set off from the Petrol station, realised what i had done. pulled over (only about 20 yrds) and switched engine off.
I was towed home - keeping the engine switched off, even if the car isnt moving but the engine is running then fuel will still get through!!
Next day syphoned out the fuel then bought a few litres of diesel and took the car to the petrol station - with another car following just incase it conked out. Then brimmed the car with v-power diesel and took the car on a really good drive to test it out.
Over the next few weeks I only let the tank get 1/2 to 3/4 empty before i filled up - making sure whatever petrol was left in the tank was being well diluted in the diesel.
I only got away with it because i didnt drive more than a few yards before i realised and killed the engine. Making sure there was a good chance little or no petrol got through.
You might also want to change the fuel filter too. I didnt do this because i dont think the petrol contaminated it.
This was about a year ago and the car has been fine since. But this all depends if or how much you ran the car....
RIP Coupe Former owner of 94 punto 55s, 96 bravo 1.6 sx (RIP) & 96 bravo 1.6sx Currently drives 98 bravo 1.6sx.
Had use of 97 fiat coupe 20vt and drives His 2006 Panda sporting multijet
Shop question? Order question see this thread Other than that - PM me
sammiboo is offline
Old 30-06-2009   #4
well i didn't start the car when i realised what i had done. i just pushed the car to the side and called the aa who took almost 3hrs to arrive even though i told them i had my 1 and a half yr old toddler with me. Only to be told that they'll only recover me and that i'll have to pay separately to a garage to remove fuel. i then decide to try and siphon petrol muyself using a cut off washing machine hose. after a few gulps of sucking petrol. i gave up when i check the fuel gauge hadn't even moved. i didn't go to bed to about 4am and had to be up for 6am with a petrol breath
had to use the the missus gas guzzler to get to work which cost me £20 for a round trip (cost £10 with the brava ) yesterday .
i managed to buy a silverline siphone pump yesterday which i tried to use last night but it didn't work. so i had a choice to use the missus car again or brave it to the fuel station lastnight and fill it up with diesel (a 50/50 petrol diesel mix) and pray to God. Guess what i did...
Old 30-06-2009   #5
yes im sure u guessed put more diesel and prayed. left car overnight and fired her up this morning and it drive 65 miles to work this morning... i LOVE fiats
Old 30-06-2009   #6
the brava jtd rocks... although i was s@%ting myself on my way to work....
Old 30-06-2009   #7
Site Sub Admin
sammiboo's Avatar
were you trying to syphon from the fuel filler or did you access the tank?
sammiboo is offline
Old 30-06-2009   #8
the tank but i wont be trying that again... i'll be putting more diesel when it gets to 3/4 full to gradually dissolve the remaining petrol
Old 03-07-2009   #9
bpetersb has donated!
The best way to remove the wrong fuel efficiently is to disconnect the main fuel line under the bonnet, connect it to a pipe running into a big enough container (or a series of smaller ones) then power up the electric fuel pump. You will then be able to pump out as much of the fuel as the pick up pipe can access right down to empty.
Because the fuel pumps on injection engines are high capacity it doesn't take long to empty a tank. Ideally you should use an outside power source to power up the pump rather than the car ignition.
Be careful of main dealers as many of them will insist that the whole fuel system will need to be replaced!! The AA have special fuel recovery vans that deal with this problem but they charge about £190 to do it for you.
bpetersb is offline
Old 03-07-2009   #10
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Most Easterly Pandas has donated!
Bolivia
Pumps are no more high capacity to older cars (your on about pressure )
Oh, and if you do this when you put petrol in a DERV your looking at buggaring the pump and most rubber components in the fuel system
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
4 Classic Panda's, Aswell as a 2004 Panda and LPG'ed Stilo both in Blue
Most Easterly Pandas is online now
Old 04-07-2009   #11
Yes I did mean pressure, but surely pressure will equal capacity in this instance?
As for your statement about buggering the components that is crap, the method of removing fuel I described is how the AA do it and their records show very few fuel pump or system problems after pump outs, even considering the amount of mis-fuelled cars, both diesel and petrol, they deal with every day.
bpetersb is offline
(G) Just put the JTD through the MOT and.... Decron Punto 3 19-05-2009 23:05
(G) Put petrol in my 1.3 diesel 500 dizzyheights 500 38 23-09-2008 08:04
Finally did it. Put petrol in diesel van.... ilovebeer Doblo 3 29-06-2008 22:08
(G) petrol put in instead of Diesel AlecTPR Marea 11 23-11-2004 15:17
Copyright ©2002 - 2010 FIAT Forum
