The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Bravo / Brava
Old 27-06-2009   #1
bravo 1.2 16v misfire, pls help
Hi all,
been having a problem with my 2001 1.2 16v bravo, its stated misfiring under load so changed coilpack, leads and plugs, didn`t cure it so had it scanned where i work ( garage/motorspares shop) no faults stored but ignition was retarded when engine was revved, changed knock sensor, which also didn`t cure it,... cam belt needed changing so changed that while double checking timing so know thats ok, nearly pulling my hair out now...i know fueling isn`t a prob coz its lobbing the un burnt fuel into the cat and backfire aswell so looking forward to replacing that soon, just wondered if anyone could throw some light on my problem, wondering if the ecu controling the ignition timing could be at fault...
many thanks...
crgbrns is offline
Old 30-06-2009   #2
Re: bravo 1.2 16v misfire, pls help
Originally Posted by crgbrns View Post
Hi all,
many thanks...
try changing oil and filter, and spark plugs (check for any signs of oil on old ones)
thugusher is offline
Old 06-07-2009   #3
cheers for the reply, oil and filters where changed months before the misfire appeared, and plugs changed when i changed coilpack and leads
as the first step to track down the misfire, plugs looked a nice toastey
colour so reakon the prob lies elsewhere... also changed crankshaft sensor
now as well and still missing under load...but still not eng man light or fault codes stored GOING MAD!!!!!!!!!!!
crgbrns is offline
Old 06-07-2009   #4
Bravo
Adrian Bravo's Avatar
Adrian Bravo has donated!
I would try a resistance test on the injectors next and a compression test.
My Wanted'z: Ink Black Bravo rear bumper and lots more.
Bravo Guides:
Adrian Bravo is offline
Old 08-07-2009   #5
thanks for reply, found a written off bravo in a breakers so off today
to get the injectors out of it, if that fails then i`l dig the compression tester out and cross my fingers, one of them probs ya can`t track down...on one hand it looks electrical ,then on the other hand it looks mechanical( no fault codes etc), thanks again mate
crgbrns is offline
Old 23-07-2009   #6
Still banging my bloody head, changed a very dirty throttle body today
but still that nasty misfire shows its ugly face. compression test ok, nice high figures and even across the cylinders,...only thing i did notice i took fuel pump out and gave filter a clean off, when i put it back togeather and stuck the ignition on to check for leaks. it seems to take forever for the fuel pump to pressure up and shut off, from turning the key to shutting off takes 7 secs...not sure if this is just a fiat thing or my pump is at deaths door, can anyone shed some light on this
crgbrns is offline
Old 23-07-2009   #7
Bravo
Has the ECU error light not come on at any point. Do you have a spare fuel rail perhaps the pressure regulator is not 100%
Always a chance the fuel pump could give you jip I suppose.
Bravo Guides:
Old 23-07-2009   #8
Here to help
bridges's Avatar
bridges has donated!
if fuel was a little restricted then weak mixture would give poor detonation,
Are all air pipes ok, no splits etc?
Ink Black Fiat coupe 20VT,
bridges is offline
Old 25-07-2009   #9
Cheers for reply guys, nope no fault codes/ light at any point which makes me think its got to be mechanical...had it on two different fault code readers one of em being a snapon , might give a new fuel pump and fuel rail ago nxt week...putting new clutch in it as well as thrust bearings eaten it self.. thanks everyone for the help...
crgbrns is offline
Old 25-07-2009   #10
Moderator
Netherlands
O2 sensor in exhaust, can go wrong without red warning light.....!
Peter Pick-Up is offline
Old 25-07-2009   #11
cheers mate, lambda sensor did cross my mind but was counting on the fact no warning lights came on , but if you say it might not switch light on i might stick it on the emission tester at work, just to count that out...will be so happy when this is sorted....more time to play with my sierra sapphire on wet roundabouts..
crgbrns is offline
Old 25-07-2009   #12
Moderator
Netherlands
I have the same issue with my 1,6-16V (Palio).
Misfiring at idle, 10% more fuel consumption, black exhaust etc.
No red warning light.
I changed coils, plugs, leads, fuel + air filter, used injection cleaner etc. all to nothing.
Emission tester at local garage showed nothing wrong....!!!!
Went to an official Fiat dealer yesterday, car was hooked on Fiat Examizer Computer: car's ECU had stored one fault: bad O2 sensor.
So that's what I'm going to change next week.
Old 26-07-2009   #13
Good to hear someone beat the horrible misfire problem...the prob with mine is at idle its fine, no misfire then as soon as you load the engine your driving down the road like a learner driver... doesn`t matter if engines hot or cold/ weathers hot or raining
crgbrns is offline
Old 26-07-2009   #14
Estonia
let us know if that helped
Stroke is offline
Old 26-07-2009   #15
Moderator
Netherlands
Misfiring in a modern ECU equipped engine is almost always ignition or fuel injection failure, due to bad sensor(s).
So you have to be a computerfreak to read the ECU or you have to go to the dealer to have it done.
I did the last, took less than 10 minutes and was free of charge!!
Did you go to a Fiat dealer already with your misfiring problem?
If you didn't, I suggest you do, have your ECU read by the Fiat Factory Examinizer computer, it's the easiest way to solve the problem!
Tags
bravo 1.2 16v, misfire
(G) Fiat Bravo 1.2 16v misfire problem. Rickathome Bravo / Brava 5 09-07-2009 21:20
(G) 16v sporting misfire itacarboy Punto 3 06-05-2008 18:56
(T) 16v turbo misfire fordy Coupe 5 21-05-2007 20:03
Copyright ©2002 - 2010 FIAT Forum
