| | #16 | ||
Posts: 594 Thanks: 35 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat Modern engines are capable of being well inside the emission requirements, so something is well out. Giving the car a good run is not really needed to get it back into order, the ecu can work that out if it gets the right info. Faulty MAP and air temp are the most obvious, look for any leak in MAP pipe etc and replace MAP if needed also air temp sensor. On the 8 valve models cambelt timing causes low vacuum with resultant MAP out of range. T.
| | #17 | ||
Posts: 7 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat well after disconnecting the battery i took the car to a quiet road,put some more treatment in that i had kindly given to me and thrashed the life out of it.i also found a small leak in the exhaust where i needed a new clamp for where the cat is connected.dont know which of these it was(possibly both)but it passed the emissions.thank you eveyone for your replies and input,especially Ffoxy,you were of great help,cheers
| | #18 | ||
Posts: 23,513 Thanks: 713 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat
__________________ | ||
| | #19 | |||
It was nothing pk1uk... happy to help, I get enough help here myself, its good to give some help back
__________________ Ex Suzuki SV1000S jockey, now just me and my 1.9 MJet Grande Punto Sporting in New Orleans Blue. 193.8 Bhp and 261ft lbs torque. | |||
| The following user says "Thank You!" to Ffoxy for this useful post: | ||
pk1uk (03-07-2009) | ||
| | #20 | ||
Posts: 18 Thanks: 0 Trader Rating: 0 | Re: emissions fail after new lambda sensor and new cat Were would this resistor be if fitted?? Any pics?? My 1.6 16v Brava has had CO emmision fail since i bought her, currently failed MOT again. Just want to check make sure the B****Y bit isn't on mine. Cheers.
| Tags |
| help bravo in need |
| | MSH | Punto | 4 | 08-07-2008 14:40 |
| | geordieno114 | Bravo / Brava | 14 | 03-07-2008 14:39 |
| | SlinkyCinqi | Cinquecento / Seicento | 2 | 09-08-2007 22:56 |
| Drivability probs - lambda\cat hdi sensor? help plz | adzul | Scudo | 11 | 30-07-2006 23:58 |
