The Bravo uses Tutela GI/A hydraulic fluid. Im not sure its wise to mix, so other than draining and refilling, you could buy some Tutela GI/A from Shop4parts.co.uk. Im not sure what properties Tutela GI/A has, otherwise if you could find a similar fluid with the same properties it should be fine.
