| | Thread Tools | Search this Thread |
| | #1 | ||||||
| | Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. Haynes Bravo and Brava Manual 3572 '95 to '00 (N to W reg) ISBN: 9781859605721 / 1859605729 While rebuilding my engine I have found an incorrect torque figure in the Haynes manual. This caused me to snap the head off a bolt. Luckily I had spare bolts and my dad is a qualified engineer he knew how to remove the end of the bolt by hitting it with a centre punch. I was fitting my clutch pressure plate to the flywheel. Something most people here would try when changing a clutch, with their Haynes manual as backup. There are 6 small M6 bolts. Incorrect!
Id guess those bolts break at 18nm after testing a few spares on my spare flywheel. Ive also checked my cinq haynes manual and that says 10Nm for its pressure plate bolts, so the Bravo Haynes book is almost certainly incorrect. Last edited by Adrian Bravo; 28-11-2009 at 13:27. | ||||||
| | Re: Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. typical Haynes book of lies
__________________ 500 door handles fit bravo well chuffed ![]() ![]() | ||
| | #3 | ||
Posts: 439 Thanks: 23 Trader Rating: 0 | Re: Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. 10 NM would be correct for the small M6 bolts.
__________________ Faster Horses, Younger Women, Older Whiskey and More Money. '99 Bravo GT TD100 and '01 Bravo JTD100 (remapped ) | ||
| | #4 | ||
| | Re: Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. Had exactly the same problem doing my clutch on a 1.4 a little while back. Double checked it with Fiat and saw that it was wrong in Haynes. Took a while to explain 0,9 daNm to my dad though.
| | #5 | ||
Posts: 235 Thanks: 6 Trader Rating: 0 | Re: Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. I have never found haynes manuals much use To be honest. "Refitting is a reversal of removal" No sh*t sherlock
__________________ Alfa Romeo GTV V6 Fiat Bravo 80 SX | ||
| | #6 | ||
Posts: 511 Thanks: 22 Trader Rating: 0 Drives: | Re: Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. They used to be good. I've got a few of me dads old manuals. When you compare the Manual of me dads for his old Tipo to my Bravo Manual they were a lot better in the past. Had clear drawings, and good instructions.
__________________ ![]() | ||
| | #7 | ||
Posts: 81 Thanks: 3 Trader Rating: 0 | Re: Haynes Bravo and Brava Manual 3572 Incorrect Torque Figure. Clutch related. How come no-ones ever raised the issue that the haynes manual dosent cover the 00-01 bosch 1.2 bravos with motorised throttle? What if someone wanted to change the potentiometer on the accelerator pedal?? Surely there must be more people out there then me that went to change an exhaust or engine transplant for the 1st time and cursed the haynes manual for not having some of this information?!
__________________ Small Ideas Easily Turn Into Neverending Projects!!! Last edited by m20b25; 28-11-2009 at 03:12. | ||
| Tags |
| 3572, error, haynes, manual, torque |
| | barnsley john | Bravo / Brava | 2 | 20-07-2007 13:03 |
