Any body done this and what were your results? mines a 1.6
Thinking of either grooved discs from red dot or somewhere but also heard about 1.8 discs?
just wanted thoughts please?
Out of intrest, how hard was the rear conversion? Ive done the 1.8 conversion on the front but that was a bolt for bolt swap. The rears just as easy? Also what bits would you need?
60 quid grooved/drilledOK thanks for all the help, when u say vented do u mean the drilled and/or grooved discs or is there a way to get air to them? yeah i think ill leave the rears tbh, still some good pads sounds like a good idea, undecided on aftermarket or 1.8 discs
THANKS
You can do the 1.8 brake conversion, have done myself, but in my opinion is a lot of work for little gain.
Contradicting yourself somewhat!Ive done the 1.8 conversion on the front but that was a bolt for bolt swap.
Hello everybody,
I'm sorry for my bad english.
I have a Brava 1,9TD 75HP and i want to put discs on rear brake. Can I use rear discs from some Bravo HGT which had rear discs by factory? How difficult it can be? Do you have some tutorial for this action?
Many thanks!
Regards,
Vladimir
Technically you wont get no vast improvement unless your car is on a track and the brakes are getting hot most of the time.
If your brakes are already vented, leave the current setup.
If you want to upgrade the brakes you can fit the 1.8 Fiat Bravo Front Brake Callipers, vented discs and pads for better braking. The Bravo HGT rear disc conversion will not improve the braking, so dont bother unless you want it for appearance reasons.
