Hi guys. I've actually got around to working on the brava again! I replaced the engine last year and due to a bottom end knock (1.6 16v MK1) and put in a MK2 1.6 engine with the MK1 manifold on. Got the loom in this afternoon and connected all the sensors etc. Then i tried to start it on a jump from the punto.
Sometimes it will start with very little effort. Then you can switch it off and try it again and it will just crank over, occasionally firing a cylinder. as its doing this, the CODE light will occasionally illuminate and the injector light aswell. The rev counter shoots about in random patterns, sometimes jumping right off the scale. The battery light is always illuminated. Even when it does start, it will often cut out a short while later.
Got some mobile clips:
Engine running. Shut it off and try to restart...
Engine starting straight away, even though nothings changed...
