Technical Fiat bravo 1.2 16v, swap to 1.6 16v
Cro_Tom
Near Zagreb,Croatia
i have a lot of problems with my 1.2 engine...(2000. year)
so i will maybe do a swap with 1.6 engine...
if there will be a big problems? i know that I must buy a new fuel pump (for 1.6 engine)...
will I have a problems with solid axie, or with a gearshift mechanizam? or maybe with electrical?
p.s. sory because of language, i'm not very good with english:bang:
On croatina language "jebo mu mamu":worship:
i doubt it is worth the effort, the 1.6 is an old engine. Fit a 1.4 (1368cc) 16v engine from a stilo / panda / punto instead. it will be a *lot* easier
Ignore the above, unless you want to be scratching your head thinking why i tried it.
Any Bravo/a or Marea Engine will fit, make sure you have all the wiring, ECU and Code Box. Do a search for ShaunCo he converted his 1.4 to a 1.6. He basically tells you how he did it. Very easy buy the sounds of it but alot of man hours.
the 1.4 16v is basically the same engine as the 1.2. It'll drop onto exactly the same mounts, use the same gearbox, same inlet, same sensors, same loom.
the 1.6 isn't FIRE derived, so guessing uses a different gearbox? So he'll need a new box as well, and then different driveshafts, different selector box?
and they are both 100bhp engines, with the 1.4 16v being lighter..
Converting a 1.4 to a 1.6 is easier, because like the 1.2 and the 1.4 (16v) they are similar engines.
So, yeah.. don't ignore me as i make more sense :p
no i havent, but i have converted 1108cc 8v car to a 1368cc 16v car, and have fitted a 1242 16v punto engine in a 1242 16v bravo, and have had ther 1242 16v engine and 1368cc 16v sat side by side.
i don't mind being wrong, so if you think i am, please explain why :)
from which year is 1.4 16V in punto?
is 1.4 16V good machine?better than old 1.6 16v?
do i have a change a ecu, or a gearbox?
i'm not sure on the punto, i think its around 2004 as well. it is a better engine than the 1.6 16v.
you don't need a new gearbox or ECU. It'd all be bolt for bolt, plug for plug. It would benefit from having the ECU remapped after it was built tho.
Are you not contradicting yourself here??
not really, a new ECU would require new coded keys etc etc to get round the immobiliser, a remap would just mean a small adjustment to the fueling, which tbh it might not even need.
Can you please explain how swapping a 1.6 16v is so much easier than swapping a 1.4 16v. Like i said, i don't mind being wrong - i would just like to know why you think i am, hell i might even agree with you.
Nog getting involved in this, lol
have done a few conversions but not the one specified, however, surely the 1.2 ECU is running different perameters to a 1.4 Engine ?
of course it is, but the 1.4 will have higher flow injectors and the extra capacity in the ECUs learning might be enough to compensate. for example, a Seicento 1108cc 8v ECU will happily run a 1242cc 16v engine.
Like i said though, i would remap it anyway to make sure it's right - BUT to run, it probably won't need it.
Your stating that it'll fit without any changes and then you say it may need a remap. But then your not sure.
Anyway i've checked both gearboxes for the 1.2 16V Bravo against a Stilo 1.4 16V and guess what they aren't the same nor do they fit each other. I've checked engine mount locations and once again are not similar nor in the correct place. This is using workshop manuals and eper. I suggest you look at eper to correct me or similar.
You said you've fitted a 1.2 16V engine from a Punto to a 1.2 16V Bravo. Correct me if im wrong but that is a like for like swap??? Those engines are the same, so no wonder they fit. I know what your saying but the Stilo engine is not a straight swap. The 1.4 16V does not share anything with the 1.2 16V.
Because the Bravo never had a 1.4 16V, but it did have a 1.6 16V. Im talking about fitting a Bravo engine into a Bravo. Not a Stilo/Panda engine into a Bravo.
come back when you have both engines in front of you, not just read about them
you are wrong. there are subtle differences. but i only mentioned, to point out that i have worked with and on both engines in question here.
the engine mounts are different, but the mouting holes for the engine mounts are still in the block and head, hence how i was able to bolt CINQUECENTO engine mounts onto a STILO engine
i said it'd benefit from a remap, but probably work without
back to the 1368 16v and 1242 16v sharing nothing.. they are pretty much the same engine. Visually they are identical. It wouldnt suprise me if the heads were interchanegable.
re the gearboxes. the part numbers will be different, of course they will - they have different ratios for the different cars, but they are the same family of box and so the box on the car already will bolt straight onto the stilo engine. just like with my cinqucento, it has a stilo engine and a cinquecento gearbox
Yeah ok im gonna go get the two engines in question just to prove you wrong. :nutter: Come back with the facts and i will praise your wisdom and proving me wrong.
I dont mind seeing pictures of your conversion with a Stilo engine into a Cinq.
Now to engines, well to plug a 1.4 16V into an ecu for a 1.2 16V, again wont work all the parameters are wrong. Do you honestly believe all ECUs are the same and all thats needed is a change in the fueling to make it work? All sensors on the car will be wrong for starters. So does that mean we all share the same ECU just with different settings for a particular engine? Really why do you think people fit the ECU from the doner car when doing an engine change besides the immobiliser issues (which can be bypassed anyway)?
I respect you've done a conversion on a Cinq but we aint talking Cinq here. If i had the time and money i could fit a Subaru engine to my Bravo, but as i keep saying its not a straight swap or a cost effective one either.
rethe gearboxes. the part numbers will be different, of course they will - they have different ratios for the different cars, but they are the same family of box and so the box on the car already will bolt straight onto the stilo engine. just like with my cinqucento, it has a stilo engine and a cinquecento gearbox
If you read my previous post i dont mention any part numbers, as i aint stupid as yes they would be different and yes gear ratios will also be different. In respect to saying a gearbox from the 1.4 16V fitting a 1.2 16V or vice versa, is just incorrect visually aswell as physically. The boxes are different in every way. The only box that does fit a Bravo 1.2 16V is from a mk1 punto 1.1 or 1.2. IF 1.4 16V boxes fitted, im sure you would of told all the Bravo 1.2 owners out there who have failed gearboxes that they can open there search to 1.4 16V boxes too.
Look i've offered my advice and Arc has offered his/hers. So do as you wish. All i will add is if you follow Arcs advice be prepared for lots of sleepless nights and loads of head scratching when you connect the 1.2 16V ECU and gearbox to the 1.4 16V engine.
Case Closed For me.
Not 100% what i meant. I was just implying that all your info is based on what you've read in part catalogues, where as what i am saying is based on experience with working with the engines that we are talking about.
My stilo engine into a cinq is documented here;
https://www.fiatforum.com/cinquecento-seicento/176286-my-1-4-16v-cinquecento-development-thread.html
here's a picture;
Because the two engines are so similar, all their sensors are pretty much identical. You'd only use the block and head from the 1.4, and you'd simply bolt the 1.2 inlet manifold onto the 1.4. The port size is the same, but the 1.4 engines tend to have fly-by-wire throttles which the Brava/o ECU would be perplexed by. You'd need the coil packs and bracket off the 1.2 as well.
People fit the ECU and loom etc from the donor car because the one in their existing car does not have connections in the correct places for all the sensors - but again, because the 1.2 and 1.4 are so similar, the brava/o loom will plug straight in. If you were to fit say, a 1.6 16v engine - you'd need the 1.6 loom, or heavily chop the 1.2 loom so as everything fits.
All ECUs are essentially the same. They have an input from a TDC sensor, throttle posisition sensor, map sensor, air temp and coolant temp, they use data from them to look up in their tables and then fire the appropiate plug or injector based on the values of its inputs. They're not complicated things. They only differ in design from car to car due to the introduction of body computers, airbag ecus etc etc which all talk via the CANBUS.
Thank-you :)
I know we're not talking Cinq here, but a brava/o isn't any more complicated than a Cinq. Fitting a 1.4 into a brava/o would be *much* easier than fitting one into a cinquecento. My cinquecento runs a megasquirt engine managment system, punto85 fuel pump, aditional fuel regulator to allow it to run the injection system for the 1.4 - in a brava/o, this would all just plug straight in.
You are just completely wrong here, the boxes do not differ physically. ANY FIRE derived block will fit ANY FIRE box. Like i have said, my 1.4 is using the Cinquecento box that the car came with. My friends 1.2 8v Seicento has a 1.1 punto gearbox on it. The only bits on the external casing that differ are the clutch and selector mechanisms, which just unbolt and can be swapped over anyway.
Case Closed For me.
Arc is a guy, despite looking a bit girly in my avatar image.. haha.
As I have said, many many times now, you would have NO trouble fitting a 1.4 16v engine to the brava/o's existing gearbox or wiring loom.
ok, thank you very much!!!
I must talk with a one good fiat proffesor in croatia, and if he sad thad is 1.4 good choice, then i will star look for engine..
So, i a need a engine without gearbox and ecu?
what about the axies? is from 1.2 good?
