Chris56000
Hi!
I have a Brava 1.9 TD100 ELX engine 182A7.000 equipped with Lucas injection tackle. (sorry I can't read whats on the pump plate)
It has come up for its 72000 mile service and in addition the alternator has died - I've got a new replacement along with a replacement new battery from my ECP factor. I've also got a new alternator belt, timing-belt, timing belt tensioner and water pump ready and some Ribe bits for their screws on order!
However on removing the top engine cover I was distinctly annoyed to find signs that its been pratted about with by someone not expert in diesel equipment servicing!!! I've found:-
1) The Cold Start valve bowden cable has no fitting on the end of the cable, its been just left draped over the injection pump doing nothing! Can I use a bicycle solderless nipple to reconnect it to the Injection Pump Fast Idle control lever?
2) There are two fairly thin and stiff black wires draped round behind the injector pump that have been connected together and taped up - can anyone offer me any idea as to what they would have been for?
The engine starts and runs but its performance is far from gratifying, it barely reaches 70mph and on a run round the Bradford/Leeds area it struggles getting away from traffic lights, most of which seem to be stuck on the top of hills!!! When my bro-in-law drove it on last years spring holiday there was black smoke coming out of the exhaust on pulling away from a stop and on downward gear changes. It passed its MOT OK including smoke density two months ago!
Also the CODE light has never come on since I got the car so I can't tell if somebody's disabled it or not!
Can anyone point me in the direction of a help guide for replacing the alternator please? It seems a right swine of a job - I had to get Fiat's manuals (both CD & binder ones!!!) as some bright spark at Haynes publishing decided not to cover the diesels!!!
The official instructions aren't very clear either - there's a big bolt going up a big cylindrical thing on the lower driver's side engine bracket which I couldn't budge - do I have to unscrew this somehow and support/lower the engine on a trolley jack to get at the alternator to remove it?
I've only got a communal parking area and I live seven floors up so I can't run mains power out to the car obviously!
Many thanks,
Chris Williams
Many thanks,
Chris Williams
