I have a Fiat Bravo HGT with the following problem;
The engine cuts out at around 4000rpm, the relays in the glove box cut out, its not the rev limiter. The rev counter jumps about 500 rpm before it cuts out, once you dipped the clutch and the revs actually drop the engine restarts.
Fiat changed the camshaft sensor and charged a fortune and then blamed the ECU. I have had the ECU checked seperately and its OK
Does anyone have any ideas??
Is it the crankshaft sensor??
Does anyone know the protocol of the 2 core ECU interface??
JD
JD
