| | #31 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Best quote ive got locally is £200 for a complete engine, I havnt tried haggling with him yet. On the web ive got £126.50, £150.00 and £149.50 delivered for complete bottom end one says reconditioned so ill ring them tomorrow and find out what state they are actually in. | ||
| | #32 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Ordered a bottom end £80. should be here tomorrow. Ive been assured its in good condition, with no bad damage on the bores. I hope it is a good un | ||
| | #33 | |||
Posts: 1,720 Thanks: 94 Trader Rating: 0 | Re: Fixing My 1.4 Bravo Engine Misfire
Hope its back and running again soon. Im suprised your confident to tackle such a job on the street, hats off to you.
__________________ ![]() FOR SALE : ePER 50 Edition DVD 2009 / Fiat Bravo Haynes Manual / Fiat Bravo & Fiat Coupe Workshop Manuals and Fiat Bravo Owners Manual in Electronic Format. | |||
| | #34 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Cheers Joske. Ive always wanted to do some serious engine work. Its a shame my car has forced me into it especially as its the worst financial position of my life. Im sure this new block will be a heap of crap, usually when I take a punt like this it blows up in my face. Ill be replacing piston rings and shells if its worthy, If its crap I wont let the driver take it off his truck. Im going to rebuild the engine then get a local garage to just put it in. then bring it back to my house and ill put the rest back together. Last edited by Adrian Bravo; 08-04-2009 at 11:22. | ||
| | #35 | ||
Posts: 12,196 Thanks: 210 Trader Rating: 0 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire why get a garage to fit, chances are thats going to bump the price up. an engine hoist is normally only around £20 to hire, and if you get one for the weekend (in particular this weekend) you'll have loads of free time to mess about with it.. and it'll stil only cost £20. i'd advise a new clutch whilst you're having the engine out | ||
| | #39 | ||
Posts: 12,196 Thanks: 210 Trader Rating: 0 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire if you do the rings, remember the block will need honing else they'll never bed in properly. | ||
| The following user says "Thank You!" to arc for this useful post: | ||
Adrian Bravo (24-04-2009) | ||
| | #40 | ||
Posts: 6,905 Blog Entries: 3 Thanks: 306 Trader Rating: 1 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire To show my very poor knowledge of these things... the replacement looks worse than the original ?
__________________ | ||
| | #41 | ||
Posts: 12,196 Thanks: 210 Trader Rating: 0 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire the cross-hatched marks you can see on the bore are honing marks, they are meant to be there, and the fact you can still see them shows the engine is not badly worn. conversly on his original block the honing marks are all but gone and there are deep vertical scratches in the bore. this is bad. | ||
| | #42 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Yeah as arc says my original has no honing marks whatsoever, Infact they are uttlerly smooth. Well apart from the very wrong vertical scratches. Cheers arc I was going to hone it and do the rings (I didnt know honing was necessary, ta for that info ) Now my dads saying dont bother with new piston rings, so im in two minds Last edited by Adrian Bravo; 24-04-2009 at 12:08. | ||
| | #43 | ||
Posts: 12,196 Thanks: 210 Trader Rating: 0 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire if it were, me, i wouldn't bother mate. It's not like the engine is going to be pushed hard - it's not got a tuned head on it, nor is it revving to silly rpm. | ||
| | #44 | ||
Posts: 1,587 Thanks: 90 Trader Rating: 0 | Re: Fixing My 1.4 Bravo Engine Misfire
__________________ Ink Black Fiat coupe 20VT, | ||
| | #45 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire my view is same as above, you can see that bottom end is in pretty good nic, the honing marks are still clear as day so i wouldnt bother replacing the rings and honing (would would probabl need oversized pistons if you did) stick in some new shells and it'll be good | ||
| Tags |
| 1.4 misfire, 12v, engine, oil |
| | nickyboy4 | Bravo / Brava | 5 | 23-02-2009 22:55 |
| Good for parts or fixing up? Bravo 1999 | Dobby | Auction Watch | 2 | 21-12-2007 13:34 |
| | Dobby | Bravo / Brava | 3 | 30-08-2006 10:00 |
| | anthonytutton | Stilo | 30 | 20-07-2006 23:40 |
