| | #17 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire cam wear is minimal, and with a good clean up and new set of valve oil seals you'll have a good head. that pitting is normal. a head gasket will seal it fine. shame the bottom end isnt worthy of it. if you're thinking long term then a scrapyard engine is best bet, but since your head is so good just get the bottom end, allowing you to inspect it with head removed before you buy, ensuring you'll get a good un.
__________________ ![]() 2.0 twinspark veloce Last edited by jug; 02-04-2009 at 14:04. | ||
| The following user says "Thank You!" to jug for this useful post: | ||
Adrian Bravo (02-04-2009) | ||
| | #18 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Cheers jug. Ill have to have a think Im doing all this on the street and I don’t have a engine hoist. A bad bottom end was my worst fear. I suppose I could get a scrap yard block delivered build it up then hire a engine hoist to fit it. What’s confusing me more than anything is piston 2 was always the one to oil up yet it looks the best and has the best compression, where as 1 has the worst compression and worst scoring. Ill spend the rest of tonight cleaning my parts and have a think. | ||
| | #19 | |||
__________________ ![]() 2.0 twinspark veloce | |||
| | #20 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Im thinking of getting a scrapyard block to my house. Putting my good head on that in the shed. Then getting a local garage to take my car and engine, pop it in. Then get them to deliver the car back to me, and ill finish it off. | ||
| | #21 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire I cleaned all my valves today, the exhaust valves where hard to do. Every inlet valve had thick carbon on the back. Infact there was only one valve that was clean cyl-3 exhaust valve was light brown on both sides. All clean now anyway | ||
| | #22 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire | ||
| | #25 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire valves good as new now. bottom end wont cost much. ring around to see.
Adrian Bravo (05-04-2009) | ||
| | #26 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire Nice one jug im ringing round first thing tomorrow for a bottom end. If i can put it together I should have a engine ready for a lot of miles.Do you recommend getting new piston rings and big end shells? Block will be bright red rocker cover black with silver letters Dip stick tube is now black | ||
| | #27 | ||
| | Re: Fixing My 1.4 Bravo Engine Misfire While ive been thinking painted my rocker cover with some old exhaust paint we had, should be good to 500deg. I did silver first very thin, then masked and painted the black. black is a bit too matt but its what i had in the shed, looks better than oxidisation. ![]() Oh if anyones got ideas on finding a good bottom end, I need inspiration. Only found 2 scrap yards local and they wont split the engine. Spoken to a few engine reconditioners but the couldnt help. Last edited by Adrian Bravo; 06-04-2009 at 18:03. | ||
| | #28 | ||
Posts: 12,195 Thanks: 210 Trader Rating: 0 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire just buy the whole engine, or buy a bigger engine? | ||
| | #30 | ||
Posts: 12,195 Thanks: 210 Trader Rating: 0 Drives: | Re: Fixing My 1.4 Bravo Engine Misfire without rubbing it in much... it is a much better engine.. better on fuel and more powerful than the 12v... didnt someone say the 1.6 / 1.8 is an easy swap? if not, if the 1242 16v goes in easily, then so will a 1368cc 16v | ||
| Tags |
| 1.4 misfire, 12v, engine, oil |
| | nickyboy4 | Bravo / Brava | 5 | 23-02-2009 22:55 |
| Good for parts or fixing up? Bravo 1999 | Dobby | Auction Watch | 2 | 21-12-2007 13:34 |
| | Dobby | Bravo / Brava | 3 | 30-08-2006 10:00 |
| | anthonytutton | Stilo | 30 | 20-07-2006 23:40 |
