Hope you guys can help
2001 (4200m) 1.6 Marea, suddenly developed poor engine performance
Well maintained, new cambelt a couple of months ago
Seems normal when cold for first few miles
Then severe lack of power (virtually undriveable) usually develops.
Can sometimes performs normally, although now rarely.
Initially no warning light to indicate any problem
Local garage has carried out diagnosis testing
Injectors checked all same resistance (16 ~ 17)
fuel pressure and flow checked OK
Car starts and idles OK
Emmisons are strange very low HC (4 ppm)
Plugs are very clean, if anything lean mixture
All cylinders running at idle
If you can drive through the lower rpm, car will start to pull after 3500rpm
But sometimes it is almost impossible to reach anything approaching this engine speed
I ran it with Lambda disconnected, although runs rough it is significantly better
seems to be lack of fuel, but why?
