Styling 500 door handles fit fiat Bravo
The Sultan
Bravo 1.8 HLX FTW
lake windermere east edge
i took a fiat 500 apart just to see what the mechanism in the handle was like and it looks to be completely identical to the bravo and the shape of the hole in door and everything looks the same so i might be trying to fit some of them at some point when i get the bonnet fixed so for anyone that has been looking at the mall fitting alfa 147 handles look no thurther if these ones work they will fit the pannel perfectly as the alfa ones have a crease running through the handle
I've always thought this for a long time, even had it saved as a favourite on ebay but they never cropped up. New they are extremely expensive. To be honest i thought this post was proof they fit but if its an assumption then its not really worth mentioning. However i look forward to the answer.
oh the way it pulls the rods for lock and to open the door is the same no problems there and the length of them two the front mounting bolt i was going to put the one i took apart into my car as a test but ran out of time
there not actually that expensive new under 30 quid each and you would need a right hand drive drivers side and a left hand drive drivers side to retain both your locks
the only thing i cant be sure on till i try is the shape that the but end locks into on the door skin but i cant see fiat retaining that handle and changing that alone specialy as the 147 is the same
i'm guna give it a try when i have time and more money and more to the point my bonnet fixed
