Duggers2000
Recently replaced my Slave Cyl. due to haemorrhaging Dot 4. That now seems sorted and the fluid level is staying full and no apparent leaks. However I have noticed that the clutch is squeeking quite a lot when pressing the pedal down and releasing it (even with engine switched off!). This doesn't appear to be coming from the pedal assembly but from under the bonnet. Coupled with this, when the engine is running there is a squeel as the clutch is engaged / disengaged (even in neutral). No other signs of distress and the car drives fairly normally - pulls away fine and gear selection seems fine. I was thinking maybe the thrust bearing??
Any ideas??
Any ideas??
