I'm having a funny problem - my 2001 Brava has "standard" Fiat OEM 15" 7-spoke alloys and 17mm head wheelbolts... I've acquired some older 14" Fiat Brava / Bravo 14" 6-spoke alloys that I thought would fit straight on. However when I tried to mount them I just couldn't get my bolts to catch in the hubs, after a lot of messing I concluded that with the new (i.e. older) wheels, there was not enough thread showing through. It seemed that the wheel was somehow thicker, and the conical hole was shallower and didn't let the bolt seat in quite as much.
Nearly all standard Fiat replacement bolts (from ebay etc) seem to be around 51mm overall length with a 25-28mm thread, which is basically what i've got.
So the question is... does anyone know if the early Brava alloys were like the Coupe alloys, and needed a longer (or different) set of bolts? Anyone got an idea where to find them?
Also, did all 90's Fiats switch to 17mm bolt heads from the earlier 19mm standard?
Cheers for any input...
