Technical starter motor
merlino
geordieland
Could anyone tell a novice the degree of difficulty of changing a starter motor on a 2000 brava/o 1 2 3 4 5 or should i get it changed by a mechanic please help me.
With 5 being the hardest and 1 being the easiest its a 3. You need some axel stands as you'll be working from under the car and you may need to remove the battery tray, airflow meter, throttle body and relevant pipes too. If you have a 1.8 you will need a cranked ring spanner.
Also note the order and positioning of the wiring to the starter motor.
