mtaylor55
Hi, first post here so I hope you can help. I've done search but not seen any posts about this problem.
Basically, my central locking always defaults to being locked. If use the key to open from the outside, it will open then shut about 1 second later. It does the same using the key fob and the same when inside and using the door handle.
I've twice got out the car and left the key in the ignition, only to the locked out.
I checked that there is nothing jammed etc.
Any ideas?
Any ideas?
