Technical Radio Problem
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
carols
Hope some kind person can help:following replacement battery the radio has gone into 'safe' mode,and although I've tried following the instructions in the manual,nothing happens when I press the 'exp' button. I have the code but can't input it!
thanks for replying - but the display does not change from 'safe' after 3 secs (or 3 hours! come to that) do you think thumping it would help?
Thanks for the suggestions - when I switched on again today it worked!! must have been locked for the full 24 hrs - aah music again!
