kaosNW
Hi i got a aftermarket alarm for my fiat bravo 1.2 sx 80 and fitted it ok, the alarm works as its ment to but it also has a remote central locking feature that i cant really set up!
basically its just 3 wires, one to up, one to down (which i think ive figured to be blue/white and a third wire to common line ( i think this is a earth so black wire?)
but my real problem is this: How do i run the wires from the dashboard to the door!!! the only thing i could think of and have tried is to pull the rubber plunger thing off from under the dash (O/S) and feed the wires through, then push the plunger back in kind of squashing the wires beside it. then i repeated the procedure on the door hinge, pulled plunger out, fed wires through and squashed it back in! is this ok? or will i be better off drilling through the footwell/door?
and where do i make the connections isit inside the door/behind the card? or in the actual hinge bit and hide it in the rubber tubing? i tried to do it in the hinge but cant find the white wire in the bundle! theres like 20 wires all tight in a bundle which are all joined to a plug thing so i cant disconnect them! :S please help!
also somone said theres a easier way using a relay under the glovebox does anyone no about this way?
