Think that the vss can serve several tasks, some cars use the sensor for speedo, I think power steering weight which increases at speed may also use this sensor and Automatics may use it to help determine gear selection.
I know diesels use a pump speed sensor to determine fuel efficiency its possible its offset against a vss signal as well as other sensor readings to determine speed, engine speed and load.
Am a little out my depth here so hopefully someone more technical will offer better explanation.
