Fiatbravo1987
- Jan 24, 2008
- 9
- 4
hey,:bang:
Ive run into a complete mystery with my bravos starting trouble,
ive got a fiat bravo 1.4 12valve, since having it ive rebuilt the engine(piston rings, conrod shells, head gasket, valve seals, camshaft kit) since then ive fitted a new alternator, starter motor, battery, earth strap, crank sensor.
But after all this it still has starting troubles.
Its abit strange it starts in mornings or when left a while fine but still not perfect. If the car is switch of then back on again or after being shops its really struggles to turn over, almost like theres not enough power.
Sometimes if you keep trying to turn over the engine it will suddendly speed up and fire up.
Im really had it with this car but it would be a shame to end it now after all the work its had done.
If anyone can help with this mystery ill really appreciated it.
Rich
Rich
