Technical dipped beam lights not working
andy16v
midlands
hi just sign up and need help also
all my other lights are working ok
side lights are ok
dipped main lights dont work (both)
full beam work ok...
check fuses ok
check bulbs ok
any ideas....?
Have you checked the light stalk and voltage at the pins that connect the bulb?
yeah no power what so ever at the pins that connect the bulb
THe next bit i'd check is that there is power at the fuse pins (only on one side)
Then back to the control stalk.
It a case of elimination I'm afraid :(
ok cheers for help;)
report back soon for a update
update time
power is getting from the control stalk to the fuses ok
but not from fuses to lights so looks like a another circuit broad were the fuses if u know what i mean...
so find out tomorrow if it all works ok
had the same problem with my bravo 1.6 sx and had to replace the stalks
for a quick fix i had to bridge the drivers side parking light live to the drivers side dipped beam live untill i could get a replacement stalk
new stalk would of cost 195.00 from fiat dealer thank god it was not that!
another fuses box was put in and they all work ok
now i can not get my radio working need the code but people got it of can not find it at the moment:bang:
Good to know you sorted it (y)
Arse :(
side lights are ok
check fuses ok
check bulbs ok
any ideas....?
Rather than posting a new topic i thought i'd hijack this one if thats ok!?
I've got exactly the same problem, fuses are ok so guessing switch or relay. Only problem is i don't know where the relay is for the dipped headlights...can anyone help?
I've searched all around the fusebox area but had no joy!
if its helps u also no problem good luck;)
Cheers Andy, managed to get it sorted in the end, was the problem with the switch as shown in the guide managed to get it sorted although broke the indcator self cancelling in the process!! Still not sure where the relay is though...
