Old 06-11-2008   #1
starter motor
right i have 1.6sx but the starter motor is goin so i was just think would a 1.4 or 1.8 start motor fit or do i have to deffo get a 1.6 one
donnabravo2k8 is offline Reply With Quote Quote
Old 06-11-2008   #2
Speed Camera Tester
ilsonemo's Avatar
ilsonemo has donated!
Re: starter motor
to be on the safe side i would defo get a 1.6 one, you can pic up a good recon one from scrap/breakers yard
hope that helps
Quote Originally Posted by Charnwood Fox View Post
Only if you've got a trump-shuffler standing behind you when you are bent over the engine bay.
ilsonemo is offline Reply With Quote Quote
Old 06-11-2008   #3
jug
blessed are the apostates
jug's Avatar
Trader Rating: 1
jug has donated!
Re: starter motor
you need the 1.6 starter motor. you can take it from any age 1.6 bravo brava or marea. i believe the 1.6 stilo also uses the same starter motor, but i cant guarantee that.
2.0 twinspark veloce
jug is offline Reply With Quote Quote
Old 10-11-2008   #4
Re: starter motor
right update got a 1.6 starter fitted it but now when cold and been sat ova nite it wont start easy turns ova great just doesnt seem to want to kickin could this be new batter or new spark plugs needed does start finaly about 1 min of trying any info people thanks
Old 10-11-2008   #5
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: starter motor
if it turns over at the correct speed then it cant be the battery.
plugs and leads can be the problem. if they have not been replaced in line wiht the service schedule then replace them asap.
poor compression is a favorite cause for cold starting problems. its the main cause of cold starting problems on high mileage cars. your 1minute of cranking to start does sound like typical compression loss symptoms.
Old 10-11-2008   #6
Re: starter motor
ok thanks and how would i get rid of that would the spark plugs do it or anything elses
Old 10-11-2008   #7
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: starter motor
poor compression is difficult and expensive to fix, usually requiring the piston rings to be replaced. lets hope it isnt the cause, but lets find out either way.
Old 10-11-2008   #8
Re: starter motor
so i need change spark plugs and leads first then if its doesnt improve it could be that.
do i really need chage lead or just plugs will the leads make a differents
Old 10-11-2008   #9
jug
jug's Avatar
Trader Rating: 1
jug has donated!
Re: starter motor
it is more likely to be a lead problem than a plug problem, but definately replace both. the leads should be replaced every 24k or 2 years.
Old 10-11-2008   #10
Re: starter motor
ok will get um changed justw eekend and let ya know if it that thanks again jug
(G) New starter motor? Most Easterly Pandas Panda (Classic) 21 29-06-2008 00:04
(G) starter motor? hixy Bravo / Brava 8 24-05-2007 11:19
(G) Starter Motor alex403 Punto (Mk2/2b) 4 12-09-2006 11:15
(T) Starter motor Firewarrior Cinquecento / Seicento 1 25-12-2005 18:32
(T) Starter motor Brymak Uno 4 16-11-2005 07:25
