Hello there!
I have a problem with my clutch... I have a Fiat Brava - 1.4 SX 12v - 1998 model.
It all started when it was getting tough to change gears day by day, (hard to change gears for 4 days) and now it is almost impossible to change gear, you have to push the clutch all the way down really hard to get it in, but even if you do that it often stalls, and I don't want to do that as I might really damage the clutch.
And now when I press down on the clutch a squeeky noise occurs, and sounds like something is really grinding... But the clutch is the same to press down as it was when I first brought it a year ago, as in it's not stiff. I have asked many people and done alot of searching around on the internet, but not a definate answer.
Most people have said it's the 'clutch slave cylinder'.
Are these the symptons of a breaking clutch slave cylinder?
Many thanks!
Many thanks!
