fiatbravo57
- Oct 12, 2008
- 8
- 4
i have a fiat bravo 1.4 sx 1998
i noticed a bit of oil on the inside of a pipe where i have to replace with an air filter i wanted to put on, i have cleaned this, along with spark plugs being changed because they had oil on them.
thought i would leave for a week, before putting on the air filter to see if probs occur again, sparks are fine, but the pipe still has a bit of oil there again. somebody has recently changed the rocker cover as i can see a seal around it, would this need to be changed again do you think?
so far since buying the bravo i have
changed:
ht leads
spark plugs
timing belt
coil pack
repaired a leak on cam cover gasket
repaired air leak from exhaust manifold with paste
and the car running seems to have improved considerably but.... !
.... when the car is not warm n i first drive off, i put it in first, when its time to change gear it wont happen! just gets stuck, this is only between 1 - 2, or downshift from 2 - 1.
secondly the revs are at 1500rpm when i first switch on, until a few minutes after driving, is this normal? anything to worry about?
lastly, there is a SLIGHT judder when my foot goes all the way down on the acc pedal, like it is losing power for a milisecond, a garage had told me i could have a leak from the downpipe of exhaust... could this be it??
SOMEBODY PLEASE PLEASE PLEASE ANSWER these questions for me as well as possible, the time and effort it has taken already is enough to fix it.
somebody help, any advice appreciated, thanks!!!
changed:
ht leads
spark plugs
timing belt
coil pack
