Hi all,
I have a 98, 1.8 Bravo, and yesterday a red light appeared on the dash board. The icon is like a rectangle (on a 45 degree angle), with 3 dotted lines coming out of it at the bottom, like a spray. Tried looking around but can't find an image of it anywhere, not sure if engine management or injectors.
The car continues to run fine. If I stop for a few minutes, the lights stays off for perhaps another 5 minutes.
Called the AA yesterday and as it has old plugs he couldn't connect his reader to it, so reset the ecu by removing the earth. Drove the car today and 5 mins later the red light back on but the car seems fine, no loss of power, no mis-firing etc. Parked up, drove back home later on (about 7 miles) and no red light.
1) Any ideas what the icon is?
2) Any ideas on why it's appearing?
3) Could it be a common fault?
4) Is it worth paying £40-£50 for a test at a garage. Don't really want to pay lots of money since it's getting old now, but I did have to get the cambelt, spark plugs, new exhaust all last year
PS- about a month ago I realised oil was leaking so had to get a new slave cylinder added. Topped up with lots of oil, not sure if that could a problem? The oil was a lower grade as I wans't sure what to put in the car, and the guy at the counter said you can't go wrong with the lower grade/numbers stuff, and it was better to go lower than higher. As I said it's been about a month, and I've done about 400 miles since that change. Could it be connected?
Many thanks.
Many thanks.
