kaosNW
Hi well ive had my bravo for about 6 months or so and it was supplied with a red key and 1 blue key.
the blue key wont fit either door but the red key does and the blue key wont start the car but it will turn the ignition on, so i think i need to reprogram the blue key but to do this i need 2 blue keys dont I? so i was wondering do i get the red key copied and borrow my friends blue punto key and put the punto code on the copy to make a new blue key
or do i get my blue key copied and put my friends code on that one? (do i need to use my friends code or can i do a straight clone of my blue one?)
Anyway heres the real problem - the otherday for no apparent reason i was driving on the motorway and suddenly the car lost power in gear 4-5 normally its quite nippy for a 1.2 but it was really weak, my foot was to the floor and the car was strugglng to get from 45-60 normally this is easy!
The engine is also noisy, cliking when i turn the engine off and it also sounds as if air is being sucked or blown when i rev it with the bonnet open, its also drinking petrol like mad!
Ive had a friend look at it and he says the engine looks in good working order, the only thing he noticed was the Throttle body was making the ticking noise so im led to belive its that causeing my probs! but he also suggested the exhaust is blowing and he said it could be the timing belt but he couldnt check as he said he needed a special tool for it??
Also today i was driving and the clutch went really stiff and sticky, i pumped it a few times and it returned to normal :bang: please can anyone help! really need the car for uni!
so far we think its either:
1) ECU so i need a new blue key
2) Throttle body
3) Timing belt(??)
does anyone know if these problems would cause these symptoms??
so could this be down to the fact that ive been starting it with the red key all this time?
2) Throttle body
3) Timing belt(??)
