My bravo was feeling sluggish on acceleration so decided to take a look under the bonnet. Took the cover off the engine and found a hose that comes from the (i think its called) air inlet duct and goes into the rocker cover and into the area above the first fuel injector, had perished and a big crack had appeared.
Went to 3 scrapyards couldnt find a bravo with an engine in it, so did a botch job with tape to try a seal the crack. Will try get part monday.
Since taping and sealing the crack the problem has got worse and now the engine warning light is flashing.
Any ideas why this light would be flashing after sealing the crack in the hose or have i got a separate unrelated problem. thanks
