GSEBravo
hi all,
i work with a guy that has an r32 skyline and he was tellling me a really good way of cleaning your engine that he found by complete accident.
all you do is when you need to change your oil, fill it up but add two litres of diesel into it. then ruint the car for about half an hour. next completely drain all of the oil and diesel from the system and put in the new stuff.
the reason this works is because the diesel will break down any carbon deposits and any other crap in the engine.
trust me it really does work. were not sure however if the amount of diesel to oil should be relative to the engine size as this has only been tried on his skyline lump which is obviously bigger then my bravo and anything like a cinq or whatever.
