General clutch judder
It is possible that the clutch friction plate has been contaminated by fluid loss. Although its a long time for it to have just started playing up.
Does the pedal feel juddery when you push it down?
what is the mileage on the car as the clutch might be on its way out.
diaphragm spring fingers seem to wear etc.
judder is the clutch or flywheel. you've only recently had the clutch fitted so i would go back to the fitter and complain.
