General Headers & Spark Plugs
emre2blue
Hi, I live in Turkey, Istanbul. I can't find supersprint exhaust headers for my 2000 model 1.6 bravo. Also I need iridium spark plugs. Where can I buy those from the net? with lowest price especially :p
you may be having trouble finding the supersprint manifold because you are searching for a "header" instead of a "manifold".
if you go to the supersprint website, and then select fiat, then select bravo 1.6, you will see the full exhaust system is available, including the manifold (thats the header -which is part number 813701)
http://www.supersprint.com/homeuk.htm
i'm sure it will be cheaper for you to go to your local car parts supplier and order the spark plugs. any supplier of sparkplugs will be able to order them for you form the main NGK supplier in turkey. this will be cheaper than paying for international delivery.
I asked local distrubuter, Number "813701" "Manifold for OEM Kat." They told me this part is no longer manufactured by SS. So I couldnt buy it. But there is a strange thing going on, Why SS still put/use its' picture on the site ?
Why do you want iridium plugs?
Performance gains (questionable as they are designed for longer service life) ?
Just curious you see I use NGK in both my car and motorbike. Wont use anything else now :)
Yes only for performance gains because, I think my car cannot burn fuel enough / efficient. There is always a smell in the exhaust pipe. I checked my engine-top 2 months ago for insufficient compression. Now its ok but, still I cannot get the power enough. And the smell still lasting. Now I'm suspicios about crank-sensor which is for spark timing, nevertheless a little performance is good ;)
trust me, no matter which plugs you use you wont get any gains compared to using the correct NGK plugs for your engine.
:confused::confused::confused: But, I'm planning to use supercharge with "HH0 thermolysis" for my machine? Is it still won't effect the burning of fuel mix then?
HHO is a scam that does not work, that has been proven decades ago.
the science behind it is correct, but it does not help your fuel economy or performance at all because you use more energy to create the gas than you get back form the gas. at school that is the first thing you learn about brown's gas.
if it really worked every single car would have it fitted as standard.
I cant believe that crap is still being peddled around. :rolleyes::)
Yeah I now it wouldn't work but, I will try some additional energy sources for only thermolysis of water. But it is still just a tought. Before the HHO stuff I have to fix other things on my car. But, heyy thank you anyway.
(y)
